Activity › Forums › Apple Final Cut Pro Legacy › reference export issue
Posted by Mike Johnson on January 29, 2009 at 1:05 pmI used to be able to export a reference file from Final Cut on one machine, and then open that reference file on another machine on my network. This week I discovered that is no longer the case. I can connect to the other computer fine, I can see the file fine. But when I open it, it is only giving me the audio. So its not actually finding the video files, the part that is actually “referenced.” I know that I could export a self-contained QT file, but that’s not the point. I used to be able to do this.
Both systems are running Leopard.
The reason I’m doing this is that we only have one license of Flip4Mac, just FYI.
Mike Johnson replied 17 years, 8 months ago 4 Members · 10 Replies -
Rafael Amador
January 29, 2009 at 1:27 pmHi Mike
In one of the computers you have the codec to read the clip. In the other you don’t have it.
Rafael -
Mike Johnson
January 29, 2009 at 1:32 pmRafael,
I don’t think that’s the case here. I have Final Cut installed on both machines. It was exported from a DV project. I know that I can play DV files on the other machine.Thanks.
Mike Johnson
January 29, 2009 at 1:41 pmOk, I’m slightly embarrassed, but not too much…
It turns out my intern had changed the settings on his machine. He was capturing to a different drive than the Ref was exported to. I wasn’t aware of this, so I was only connecting to the drive with the Ref file, assuming (yes, I know the old adage) that they were on the same. As soon as I connected to both drives, the file opened up fine.
Rafael Amador
January 29, 2009 at 2:10 pmThen you should have got a warning; Media not found.
May be you didn’t because the audio was on-line.
That is the typical scenario of “codec not found”.
I thought you could be with ProRess XDCAM or so.
Cheers,
rafael -
David Roth weiss
January 29, 2009 at 2:25 pmA reference file is not supposed to play on another machine, you need to make a self contained file.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
David Roth weiss
David Roth Weiss
Director/Editor
Walter Biscardi
January 29, 2009 at 2:34 pm[David Roth Weiss] “A reference file is not supposed to play on another machine, you need to make a self contained file. “
Using a SAN this can work just fine.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
David Roth weiss
January 29, 2009 at 2:39 pmIs he working on a SAN?
David Roth Weiss
Director/Editor
Mike Johnson
January 29, 2009 at 2:40 pmWhether or not its “supposed to,” I’ve been doing it for 3 years. Please don’t read this as being snarky, but you did see that I’m bouncing these around within the same network, right? I’ve always been able to mount a shared drive on another machine and run the Ref file, both in quicktime and compressor. I would never use a Ref from another machine in Final Cut, or anything that actually needed to play it back, but for compression or file conversion I’ve always done it.
Mike Johnson
January 29, 2009 at 2:41 pmNope, I’m not on a SAN. Just several computers connected through a router. File sharing is enabled. I mount the appropriate drive on the shared computer and open up the reference file. That’s it. 🙂
