Activity › Forums › Adobe After Effects Expressions › Reference and pauze to Comps frame or marker in other comp
  • Reference and pauze to Comps frame or marker in other comp
    Posted by Bas V breugel on April 5, 2018 at 9:27 am
    Hi guys,
    I find this diffecult to explain, so I recorded my screen to get what I’m trying to solve.
    So, if you would enter ‘ARG’ for position 1 in the “1_RACING_INPUT” comp, it would show the Argentinian flag, freezed on that frame.
    textLayer = comp("1_RACING_INPUT").layer("01_country");
    str1 = thisLayer.name.split("flag")[1];
    str2 = textLayer.text.sourceText;
    str1 = str1.toUpperCase();
    str2 = str2.toUpperCase();
    if (str1 == str2) { goto marker in comp("flag") and pauze
    Is that doable?
    Hammers Nail replied 8 years, 5 months ago 2 Members · 5 Replies
  • Hammers Nail
    April 5, 2018 at 10:14 am
    Why would you use markers? You have a timecode already. Make all the flags one second long and precomp in one sequence, then in main comp select that flag precomp and go to Time->Freeze Frame, and add your expression to the Time Remap channel (you should see a square key there now). Basically your expression should generate static second/frame number based on text you enter.
    if (str1 == str2) a = 1; // this will display flag that is visible at 00:01:00 .. if your flags are frame long, then divide a with framerate, like a/25
    a;
    Nh
  • Bas V breugel
    April 5, 2018 at 11:23 am
    Hi Neil, thanks for your time! You are right that the flag comp now links to the time where is the flag.
    But its not driven by the text input. I guess somewhere AE needs to know that ARG equals 7 (00:07:00)
  • Hammers Nail
    April 5, 2018 at 11:38 pm
    you are right – my code is just replacement of the last line in your code.. blend those, add more values for other flags.
    Nh
  • Bas V breugel
    April 6, 2018 at 7:22 am
    Aah something more like this I guess?
    str1 = textLayer.text.sourceText;
    if (str1 == 'ARG') stopFrame = 90;
    if (str1 == 'BRA') stopFrame = 100;
    if (str1 == 'USA') stopFrame = 112;
    t = Math.min(time,framesToTime(stopFrame));
    Only it gives AE the expression error, orange bar.
  • Hammers Nail
    April 6, 2018 at 12:39 pm
    This works for me.
    textLayer = thisComp.layer("01_country");
    str1 = textLayer.text.sourceText; str1 = str1.toUpperCase();
    if (str1 == 'ARG') ss = 90;
    if (str1 == 'BRA') ss = 100;
    if (str1 == 'USA') ss = 112;
    else ss = 0; // or else you will get warning message and expression gets disabled. I'd leave this frame empty in the flags precomp.
    framesToTime(ss); // you are after a static frame, right? if animation, like flag wave, is needed, then approach will be different.
    Nh
