Activity Forums Adobe After Effects Expressions Reference a layer or comp without duplicating it
  • Reference a layer or comp without duplicating it
    Posted by Kamel Labiad on May 29, 2018 at 1:27 am
    Hi
    is there a way to reference a comp or layer without duplicating it? I mean I want to put an adjustment layer and that adjustment layer will act as a comp or a layer I reference in that same comp
    thank you
    Kamel Labiad replied 8 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Kalleheikki Kannisto
    May 31, 2018 at 5:30 pm
    More information needed… what is it are you trying to accomplish? Sounds like this might be something that should be done with a precomp that is used in more than one comp, but that is hard to tell without knowing the desired end result.
    Senior Graphic Designer
  • Kamel Labiad
    May 31, 2018 at 6:38 pm
    actually, it will behave exactly like pre-comp but instead of doing that I want to have (for example) an effect I drag on solid and then reference a comp and it shows the content of that comp, I am actually trying to find a simpler way to make chromatic abortion without duplicating the comp
    thank you
    June 2, 2018 at 1:47 pm
    Plugins make life simpler:
    https://aescripts.com/efx-chromatic-aberration/
    Or maybe this:
    https://www.youtube.com/watch?v=ubmOZX1B51A
  • Kamel Labiad
    June 2, 2018 at 3:36 pm
    I have seen this one before, but I am still looking how to reference a comp
    thank you
    June 3, 2018 at 9:11 am
    You can blend another layer with the current one with Blend effect.
  • Kamel Labiad
    June 3, 2018 at 3:58 pm
    what that has to do with referencing a comp?
  • Griffin Englander
    June 4, 2018 at 6:38 am
    If you’re already creating another layer to reference it, what’s so wrong with using a copy of the pre-comp?
  • Kamel Labiad
    June 4, 2018 at 9:03 am
    because the effect cannot be templated that way, it would require extra manual steps
