Activity Forums Adobe After Effects Expressions refer to a layer’s name in a precomp in conditional expression
  • refer to a layer’s name in a precomp in conditional expression
    Posted by Ido Shor on September 12, 2018 at 1:16 pm
    been searching a lot before I posted this, but didn’t get anything yet.
    lets say I have a comp named “Comp01” and inside it two layers:
    1# – pre-comp named “Precomp 001”
    2# – White solid
    I want “White solid” to change it’s opacity value to 0 if there is a layer inside “Precomp 001” that is called “black soild”
    it’s a bit confusing, but it’s part of a bigger automated script I am working on that can reconstruct the layers in the Precomp 001.
    so basicly. I need an expression that can go inside a certain precomp, search for a certain layer name (based on the index number maybe) and if it finds it there than to change a certain property in the layer it’s assigned to.
    is that clear enough?
    thnx
    I.
    James Ronan replied 7 years, 11 months ago 2 Members · 1 Reply
  • James Ronan
    September 12, 2018 at 2:22 pm
    Maybe something like this, on the opacity layer of the White Solid.
    try{
    comp("Precomp 001").layer("Black Solid");
    0
    }catch(err){
    100
