Activity › Forums › Apple Final Cut Pro Legacy › refection on the floor effect
  • refection on the floor effect
    Posted by Uroshgorazd on August 6, 2007 at 9:38 am
    hello
    I am new in this stuff and I saw everywhere in Apple’s tutorials and movies about FCP this effect when the text or the image is reflected in a virtual floor. Is this duplicate-reflect-maskwithgradient thing or there is some effect, setting or something because I see a lot of this effect arround.
    Thank you very much
    Randy Johnson replied 19 years, 1 month ago 2 Members · 1 Reply
  • Randy Johnson
    August 6, 2007 at 1:40 pm
    Just about everyone does this differently. After duplicating the clip go into the motion tab and play with the distort to give it the right shape, or you use a move 3d filter to get the perspective…then depending on how much Fall off you are looking for you make a gradiant, then create a mask for it…and there you have it. Matching the color tends be the difficult part of this. If you are not too worried about having a perfect fall off you could always just drop the opacity and skip the gradiant mask…but i dont suggest it.
    This is pretty much the same method as creating shadows too…only then you desaturate your text and give it a higher contrast first.
