Ref files lighten when fading or showing titles
Posted by Tim Silva on May 5, 2010 at 8:58 pmWhy do my Ref movies lighten when showing a fade or showing titles – the entire frame lightens and even shrinks slightly?
Tim
Tim Silva replied 16 years, 4 months ago 3 Members · 3 Replies -
Floh Peters
May 6, 2010 at 12:56 pmThis is the usual problems with mixed codecs in by reference files. You use one codec for acquire (e.g. ProRes or DV), and another one for rendering (e.g. Media 100), and you get these jumps in the by ref or self contained exports. This is a underlying QuickTime codec issue, there is nothing Media 100 can do about that. If you see this problem you should export to QuickTime into a codec and colorspace of your choice.
Matt Mullen
May 6, 2010 at 3:09 pmYou’ll see this in other NLE’s as well.
Tim, check your settings and confirm with us if this is the case.
-Matt
Tim Silva
May 6, 2010 at 5:29 pmSo, once I changed the rendering codec to match the capture codec I re-rendered transitions and title. That did seem to do the trick. This is something I have run into on occasion and never realized the cause. Thanks to all here for your suggestions.
Tim
