Activity › Forums › Adobe After Effects Expressions › Reeplace content of a layer
  • Reeplace content of a layer
    Posted by Peter Parker on October 28, 2015 at 2:24 am
    Hello ,
    I am new to After Effects scripting and I have been playing with the language. This is the visual setup of the project I have :
    Now , as a test , I have the following script :
    app.project.activeItem.layers[1].sourceText.setValue('Hello World')
    If I run this little script, I am able to change the text of my layer 1 from This is a test to ‘Hello World’.
    My question is , how can I do this operation when I am not active at the layer?
    As far as I know , if we run :
    var activeItemid = app.project.activeItem.id;
    alert(activeItemid)
    I am able to get the id of the current item :
    But , If I try :
    app.project.item(activeItemid).layers[2].sourceText.setValue('This is just a test')
    It does not work.
    Can you explain me how does this work?
    Thank you.
    Peter Parker replied 10 years, 11 months ago 2 Members · 2 Replies
  • Miguel De mendoza
    October 28, 2015 at 9:47 am
    You can’t access to comp by name directly, you must do it by index or by writing a findComp function like this:
    function findComp(compName){
    var proj = app.project;
    for(var i = 1; i <= proj.numItems; i++){
    var comp = proj.item(i);
    if(!(comp instanceof CompItem) || comp.name != compName){
    continue;
    else {
    return comp;
    Other problem is that you only have one layer on your comp, so you can`t acces layer[2]. In layers case, you can acces layer by name. You can write this bellow findComp function:
    var myComp = findComp("Text 01");
    myComp.layer("Layer 1").text.sourceText.setValue( "Your value");
  • Peter Parker
    October 28, 2015 at 11:08 am
    This is exactly what I was looking for. proj.item(i); was the key , and that function you provided is pretty useful. Thank you!
