Activity Forums Apple Final Cut Pro Legacy reencoding HDV to DVCPro HD vs batch digitize source as DVCPro HD
  • reencoding HDV to DVCPro HD vs batch digitize source as DVCPro HD
    Posted by Kozo Okumura on July 9, 2007 at 2:12 pm
    I am working on a project shot by HDV. The source tapes are already digitize as HDV through Firewire. But eventually we are going to deliver as DVCPro HD codec.
    My question is that what is the difference in quality of video between
    1. After offline editing in HDV, you through your HDV sequence into DVC Pro HD timeline and render everything.
    2. Batch digitize the clip as DVCPro HD through HD-SDI from HDV deck.
    Is the path 2 better?
    thank you
    Adam Smith replied 19 years, 2 months ago 4 Members · 4 Replies
  • Walter Biscardi
    July 9, 2007 at 2:38 pm
    [kutmasta] “Is the path 2 better?”
    Yes
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Kozo Okumura
    July 9, 2007 at 3:18 pm
    could you explain more? how much difference?
    I am not exporting the finished HDV quicktime to DVCPro HD timeline to render. I am just copying and paste the clips on the timeline to DVCPro HD so that the graphics, effects, etc are going to be rendered as DVCPro HD which has better color sampling rate.
    Is still path2 much better in quality?
  • Chris Poisson
    July 9, 2007 at 5:29 pm
    The inclusion of SDI for ingest in this workflow will not add quality to your HDV footage.
    I don’t think you would see any difference in quality by using your native HDV captured via Firewire and working in a DVCproHD sequence. There are boatloads of discussions on this right here and in the HDV forum. I have been doing it this way for a couple of months and the quality is outstanding.
  • Adam Smith
    July 9, 2007 at 7:23 pm
    Note that Chris is saying that it’s better to edit in a DVCPROHD timeline, to avoid re-compressing or creating new content in the lossy HDV codec.
    As far as converting vs recapturing, I think the biggest difference would be time required to recapture versus time required to transcode the timeline.
    2 more issues I’d worry about (I’m a noob)…
    *Final project data backups – if you need to archive the project, backing up HDV source and edit media plus DVCPRO-HD final converted media could require more storage than if the whole project was reduced to one timeline and no transcode.
    *Ability to rebuild and revise – would footage transcoded in this manner retain timecode links to the source tapes?
    Video Photographer / Avid Editor
    Maximus Media Inc.
