Activity › Forums › Apple Final Cut Pro Legacy › reducing size of picture on a white screen
  • reducing size of picture on a white screen
    Posted by Ofer Meir on August 15, 2009 at 10:00 pm
    hello to all
    I am editing a music video clip in fcp.
    I am tryibg to reduce the size of the picture i have so i can have a few “windows”of people singing at the same time. all the singers have a white screen in the background.
    the problem is that after reducing the picture to less than 40-45% the picture becomes really unclear.
    my question is: is it because of the white screen or am i having a deferent problem, maybe with the capture seting or with the fcp one?
    the movie have been shot in dv-pal 16:9
    thanks alot
    Nick Meyers replied 17 years, 1 month ago 4 Members · 5 Replies
  • David Roth weiss
    August 15, 2009 at 10:04 pm
    Are you rendering after the resize? You need to.
    And, make certain that “Full” is checked in the Render All dropdown menu before rendering. It is not checked by default as it comes form the factory.
    And, make sure you canvas size is set to 100%.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Ofer Meir
    August 15, 2009 at 10:55 pm
    thanks for you quik response.
    It helped removing some of the problem. the picture is now much much better, though still not great. there is some pixelization and it is not as clear as the 100% one.
    when i reduce a good picture isnt it supposed to stay good only smaller? am I looking for a clear picture that i will not be able to get?
  • Michael Gissing
    August 16, 2009 at 12:07 am
    DV codec is part of the problem. If you drop your edit into an uncompressed or ProRes sequence, you should see better resolution after render.
    I have also read opinion that third party software like Innobits Video Purifier does a better job of rescaling than FCP. There are also other rescaling plugins out there, so a search of the forum for rescale or resize might help.
  • Ofer Meir
    August 16, 2009 at 12:47 am
    it worked. thank you very much
  • Nick Meyers
    August 16, 2009 at 7:08 am
    finally, make suer you sequence is set to “Best” motion scaling.
    do that in the sequence settings > Video tab.
    nick
