Activity Forums DaVinci Resolve Reducing screen size creates larger file
  • Reducing screen size creates larger file
    Posted by Jim Lightfoot on August 28, 2022 at 12:58 am
    I’m an occasional user of Resolve but one thing that surprised me was when trying to reduce a screen size from 1920 x 1080 to 1280 x 720 ended with the original 1080 2GB mp4 being inflated to a 720 5GB .mov. The issue being the significant size increase.
    I used the standard Export to Youtube option to create a H.264 file in mono as it was a Zoom recording. Data rate 7.12 Mbits/s, AAC, 4800 Hz. The original mp4 had “current size 1440 x 810” via get info in QuickTime and I don’t know what that refers to as its format is listed as 1920 x 1080. Any ideas what’s going on here?
    Tero Ahlfors replied 4 years ago 2 Members · 1 Reply
  • Tero Ahlfors
    August 28, 2022 at 2:26 pm
    If your exported file is bigger, then your exported format/codec is using a bigger bit rate than the original file. If you want a smaller file then set a lower bit rate.
