Activity Forums Avid Media Composer reducing render times
  • reducing render times
    Posted by Scott Davis on July 30, 2007 at 4:12 pm
    Avid Newscutter w/ Adrenaline.
    I am working on a show that is fairly simple. We are repurposing content with a bug, lower thirds, and a couple of other misc graphic elements. Nothing that complex. Render times are killing us. The bug is a pict with a matte. If I take it into AE and make a QT with an alpha will that take less time to render? Any other tips on reducing renders?
    Scott Davis
    Rory Brennan replied 18 years, 9 months ago 3 Members · 3 Replies
  • Michael Hancock
    July 30, 2007 at 4:25 pm
    What resolution are your graphics? If you’re creating them at 1:1 you’ll get less realtime playback, which means you’ll render more. Try creating them at 2:1 or 3:1–you’ll likely not see a quality hit, but you should get more realtime playback.
    Also, if your matte key effects/titles are set to render in High Quality (the HQ button in the effect editor) it’ll take forever to render. If you have HQ on, turn it off and you’ll probably see realtime playback.
    Also, rendering your bug as a quicktime with alpha won’t save you anything in render times.
    Depending on your resolution and how many layers of graphics you have, as well as the power of your system, you should get realtime or close to realtime playback, with very fast render times. I’m guessing you have HQ set.
    Michael.
  • Scott Davis
    July 30, 2007 at 5:54 pm
    Thanks Michael, grapics are 2:1. I will check the HQ thing tonight when I go in to work.
    Scott Davis
  • Rory Brennan
    August 2, 2007 at 9:09 pm
    You’ve Probably resolved this but check ou this link. It is info from Avid fro reducing Render time.
    https://www.avid.com/resources/tips_techniques/rendering_comm.html?featureID=626&marketID=1
    Cheers.
