Activity Forums Adobe After Effects Reducing pixels?
  • Reducing pixels?
    Posted by Reuben Lemer on January 14, 2008 at 4:23 pm
    I’m quite new to this website… I hope I am typing in the adobe after effects forum… But anyway, I was wondering if anyone knew how to reduce the number of pixels in an image? It sound simple enough, but I cant find a way to do it. The reason I want to do it is because whenever I’m filming, I’m using a low quality camera, and when I take footage off the web of make some effects, it just doesn’t look right because it has more quality than the original scene.
    Can anyone help me please?
    r4z2
    Reuben Lemer replied 18 years, 6 months ago 2 Members · 2 Replies
  • Kevin Camp
    January 14, 2008 at 5:53 pm
    i’m not sure that i am understanding what you are doing…
    but if you have low resolution footage (say 320×240), you can work in a comp the is that resolution. same goes for frame rate… if you are using footage that is 15 fps, you can create a comp that is also 15 fps.
    you’re not forced to use a standard preset like dv (720×480, 29.97 fps). you can change those settings and even create your own presets to suit your needs.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Reuben Lemer
    March 27, 2008 at 12:13 pm
    Just found what I was looking for, the effects called ‘mosaic’ from sapphire plug-ins 🙂
