Activity › Forums › Maxon Cinema 4D › Reducing HDRI Brightness not working Physical/Standard
  • Reducing HDRI Brightness not working Physical/Standard
    Posted by Shynn Sup on June 20, 2021 at 11:05 pm
    Hi guys,
    I am having some trouble controlling the brightness of my HDRI.
    I am applying an HDRI as usual:
    New Default Material>Luminance>Add HDRI file>Set Brightness value>Assign to sky object.
    Now, I tried render both at 0% brightness and 500% and no difference.
    I also read somewhere you had to go into the illumination tab of the material (at the bottom) and change the strength values of the Generate GI parameter. Again no difference.
    Shynn Sup replied 5 years, 3 months ago 1 Member · 1 Reply
  • Shynn Sup
    June 20, 2021 at 11:32 pm
    Okay I actually figured it out, I had to change the Mix Mode to Multiply ?
