Activity › Forums › Adobe Premiere Pro › Reducing Flicker from lighting
Posted by Amber Sanders on October 3, 2015 at 1:50 pmHi there,
I have some footage that was filmed 25p 1/50 shutter on a canon 5d mkiii in a 50z area. I think the lighting was slightly out of the 50hz range so i have lighting flicker on the footage.
I have read about using Denoiser to reduce it, but am having no success, can any one help me with the settings?
I have Red Ginat Denoiser II installed
Thank you!
Kevin Rag replied 9 years, 7 months ago 6 Members · 9 Replies -
Massimo Alberto croce
October 3, 2015 at 2:13 pmPut another copy of the clip in superimpose at 50% slip it by one frame.
Massimo Alberto Croce
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com -
Amber Sanders
October 3, 2015 at 2:16 pmHi Massimo, thanks for your message
sorry just so i understand clearly
Do you mean so that the superimosed clip is one frame ahead/behind?
Chris Wright
October 3, 2015 at 3:38 pmdoes the flicker affect the whole image?
i made a deflicker a while back.
after effects cs3
https://f1.creativecow.net/6154/auto-white-balance-cs3-and-upif you enable the text layer and scroll Gamma Clamp at gamma*10 so that the text box reads 25, it will
fix timelapse and old movie’s flicker.these work in premiere:
https://www.granitebaysoftware.com/products/productgbd.aspx
https://www.digitalanarchy.com/Flicker/main.html
https://www.revisionfx.com/products/deflicker/ -
October 3, 2015 at 7:00 pmYes. This method introduce a little bit of motion blur, but you I think this is better than flickering.
Amber Sanders
October 4, 2015 at 7:21 amIt does, annoyingly i would not be able to mask it.
I have just tried FlickerFree by Digital Anarchy and i really seems to have don’t the job, although just using the trial at the moment, annoyingly buying it takes a chunk out of my rate for the job, but it might be the best option.
Thanks Chris i will try those now
Amber
Ann Bens
October 4, 2015 at 10:06 amI recently had the same issue: different light frequency.
Used DE:Flicker from DE:Vision.
Not a cheap solution but it fixed my problem.———————————————–
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional -
Micah Eavenson
February 8, 2017 at 9:55 pmThis is an old thread. However, perhaps this screencast could help someone in the future.
https://www.youtube.com/watch?v=rAWbVDf0hzA&t=5s
https://www.videoprowess.com
Live, Love, ShootSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Kevin Rag
February 10, 2017 at 7:09 amI usually use FCP X or PrPro but had to use Avid a few months back at a client’s place. There is a flicker removal filter in MC that works really well. AM not sure if it was a third party plugin or a built in filter though.
Kannan Raghavan
The Big Toad Films Pte. Ltd.
