Activity Forums Apple Final Cut Pro Legacy Reducing Acne in Post?
  • Reducing Acne in Post?
    Posted by Grant Wilber on May 8, 2010 at 11:38 am
    I did an interview with someone and they have pretty bad acne (Caucasian teen). Any tips on some adjustments or color correction things I could do to reduce it or look less distracting? Obviously I’m not thinking I can take it away, just somehow lessen it. Thanks
    Jerry Hofmann replied 16 years, 4 months ago 6 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    May 8, 2010 at 12:07 pm
    https://www.sheffieldsoftworks.com/ Take a look at “Electronic Makeup Artist”.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Mark Petereit
    May 8, 2010 at 12:37 pm
    Check out Beauty Box.
  • Jason Jenkins
    May 8, 2010 at 4:26 pm
    You could play with taking some of the red out of the image with the color corrector. There is also the old beauty stand-by of duplicating the clip above itself, adding blur to the top layer and then playing with the opacity. Done judiciously, it can really help.
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Shane Ross
    May 8, 2010 at 4:31 pm
    Jerry, the Sheffield Softworks one made for Acne is called DIGITAL COVER UP.
    Shane
  • Mark Petereit
    May 8, 2010 at 8:21 pm
    Beauty Box IS the one Digital Anarchy just released. 😉
  • Shane Ross
    May 8, 2010 at 9:22 pm
    Beauty Box takes 10 times the render time as the Sheffield Softworks one. Fine if you have one or two shots, but if you have a lot…that can mean hours, or days, of render time.
    Shane
  • Peter Schulze
    May 9, 2010 at 1:56 am
    Jason, great quick and easy way. May I suggest changing the composite mode to “soft light” (top layer) with gaussian blur set to around 10 before changing opacity.
  • Jerry Hofmann
    May 9, 2010 at 11:04 pm
    He has one for pimples?! Cool. I’ll bet it works.
    Jerry
