Activity Forums Adobe After Effects Expressions Reduce the motion of a tracked element
  • Reduce the motion of a tracked element
    Posted by Chris Craig on February 24, 2017 at 11:42 pm
    Hi guys
    I have tracked a person running, and I would like to have some text animate next to them, but because of the rather large vertical motion of the running style, it is making my text rather illegible.
    I have tracked a nose and applied a beam effect as a line. The other end of the beam effect is attached to the text.
    Is there an expression that can control/reduce the range of motion?
    Thanks a lot
    Kevin Camp replied 9 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camp
    February 25, 2017 at 1:08 am
    you might try the smooth() function, it will sort of average the movement over a segment of time… try adding this expression to the position property of the tracked layer:
    smooth( .2, 5 )
    where .2 is the time segment (in seconds) and 5 is the number of samples it will average…. it seems a little redundant, but increasing the time segment and the number of samples should produce smoother results.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
