Activity › Forums › Maxon Cinema 4D › Reduce specific part of mesh?
  • Reduce specific part of mesh?
    Posted by John Sharkey on January 3, 2019 at 6:19 pm
    I’m using the polygon reduction tool to lower the geometry of an object, but it starts removing geometry from a part of the object with a relatively low polygon count instead of lowering the polygon count of other, high-count areas. How can I reduce a specific part of the mesh, preferably through a selection? I understand I can use the split tool to make selected polygons a new object, and then reduce that new object separately, but I’d like to keep everything as one mesh so I don’t have to connect every polygon from my new object back to the original mesh when I’m done. Any advice?
    Also, this is my first time posting on creativecow, so I hope this post wasn’t too confusing.
    Brian Jones replied 7 years, 9 months ago 2 Members · 1 Reply
  • Brian Jones
    January 3, 2019 at 10:35 pm
    not confusing but no method other than trying out the option to preserve UV boundaries
