Activity › Forums › Apple Final Cut Pro Legacy › Reduce .mov file size
  • Jeff Greenberg
    March 10, 2011 at 4:04 am
    Compressor comes with FCP; and theres a preset for youtube (you can upload files larger than 100mbs)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Bret Williams
    March 10, 2011 at 4:10 am
    The file size is only a meaningful number in relationship to the length of the video. Is it an hour? 5 minutes? 1.7 gigs really isn’t that big.
    But, export it as qt, h264 codec, with medium or a little better quality. Change the frame size 853×480 if it’s HD or 480×360 if it’s 4:3.
  • Scott Wilkinson
    March 10, 2011 at 5:21 pm
    Jeff, I have Express…not Pro.
    The length of the video is just around 2 minutes. Thanks Bret, I’ll follow your advise
    I built a video a couple years ago and just recalled that I used iskysoft video converter.
    https://www.iskysoft.com/
  • Jeff Greenberg
    March 10, 2011 at 6:09 pm
    Sorry to miss the “Express” part – I don’t know if Cow has an express forum.
    Meanwhile – @ 2 minutes, if you’re going to manually use h.264, I suggest you use the data rate of approx. 6000 for your video – this will yield a file, a little under 100 megabytes
    Best,
    Jeff G
  • Wahida Chowdhury
    July 25, 2012 at 2:20 pm
    Hi bret,
    I made a movie with .mov files. the file sizes added up to 12 gb. now after I made the movie with final cut pro and exported the movie, the movie size ended up to be 94 GB!!!!!!!!!!! what does this mean?
    What can I do reduce the size of my movie? any idea?
