Activity Forums Adobe After Effects Reduce Interlace Flicker or Fluorescents LED
  • Reduce Interlace Flicker or Fluorescents LED
    Posted by Ben Beeny on December 7, 2017 at 10:59 am
    Hello All
    I shooted a shortfilm with SONY A7S ii in hospital (The lamps (Fluorescents type )were on the ceiling) and then check out in edit , i see the lines are similar to the tape or Flicker or band etc. on all the films
    please help me, how can i do !! ☹
    Ben Beeny replied 8 years, 9 months ago 2 Members · 4 Replies
  • Ben Beeny
    December 7, 2017 at 5:06 pm
    i drawed those with Paint program for easier understanding for understanding bright and black stripes.
    11941_10011.mp4.zip
  • Ben Beeny
    December 7, 2017 at 5:30 pm
    whaaaaat ? 😮
    first question:
    you mean that could not see any Flicker or Band or any bright-black stripes behind my actress ? 😮
    but i can see it , those movement too !!
    second:
    can u see it (bright-black stripes) in blew picture?
    i test Rolling Shutter Removal in AE 2017 but not work!
    what does it mean?
    Follow your dreams,they know ways.
  • Mike Phillips
    December 7, 2017 at 6:14 pm
    Is it flickering in the video? If so GBDflicker by Granite Bay works well. I use it all the time to remove florescent flicker. If it is just lines in the video you do not like on the wall for example. You could take a frame remove the distracting lines in photoshop with clone brush or spot or what ever works, then roto your talent revealing the clean background but this depends on your scene.
  • Ben Beeny
    December 7, 2017 at 7:07 pm
    i tested GBDflicker PLUGIN but it did not have the slightest effect on this video 😐
