Activity Forums VEGAS Pro Reduce interlace flicker on pic in pic.
  • Reduce interlace flicker on pic in pic.
    Posted by Frankie on May 18, 2005 at 12:55 am
    I’m doing a picture in picture and noticed thatthere’s a flicker.
    Is ‘switches -> reduce interlace flicker’ the only method of removing the
    flicker?
    Reason I ask is that I can kind of still see a flicker. Is that switch suppose
    to remove the flicker completely?
    Is the flicker an artifact that simply can’t be removed totally?
    Vegas 5.0
    -Frankie
    Edward Troxel replied 21 years, 3 months ago 2 Members · 1 Reply
  • Edward Troxel
    May 18, 2005 at 3:49 am
    You could also try adding a slight blur.
    Edward Troxel
    JETDV Scripts
