Activity Forums Adobe Premiere Pro reduce frame rate for playback
  • reduce frame rate for playback
    Posted by Fennie Ng on December 16, 2009 at 10:28 pm
    The videos are jittery in multcam monitor. I’m not able to view close to RT. One suggestion from a friend using FCP is to drop down the frame rate for playback. I can’t find that in PPr.
    Does anyone know how to make my videos not lagging for multicam?
    Fennie Ng
    Mike Cohen replied 16 years, 8 months ago 2 Members · 1 Reply
  • Mike Cohen
    December 17, 2009 at 3:21 am
    set the viewer to Draft playback – that is the closest you can get. If using the Multi-cam mode, you are playing up to 4 streams of video simultaneously – that will make your computer crawl unless you are running video off a RAID or really fast drives.
    Mike
