Activity Forums Adobe Audition reduce bass, and remove soundbooth effects
  • reduce bass, and remove soundbooth effects
    Posted by Tyler Smith on December 22, 2010 at 4:35 am
    I have been tweaking a few audio clips, saved in sound booth but now want to remove the effects/changes and get the original audio clip back in premiere…how do i do that?
    Whats the best way to remove bass from an interview/VO?
    cheers in advance!
    Tyler
    Andrew Devis replied 15 years, 8 months ago 2 Members · 1 Reply
  • Andrew Devis
    December 22, 2010 at 7:27 pm
    Hi Tyler
    To get back to the original it all depends how you have worked in the first place. If you have edited the file and saved it and shut down Soundbooth you can’t get back to the original unless you have saved an original version. For future reference see my tutorial on safe editing in Soundbooth using the asnd file format.
    To remove base, apply an eq effect and then lower the low frequency settings.
    Hope this helps
    Andrew
    … because it’s all about stories …
