Activity Forums Maxon Cinema 4D Redshift texture issue
  • Redshift texture issue
    Posted by Matt Rossi on August 30, 2024 at 4:00 pm
    Hello!
    I applied an animated texture (PNG sequence) to a face of an object. It looks great in the RS Render View, but it is incredibly low quality in the viewport and also not reflecting the rotation change I made to it?
    Does anyone know how to set up a higher quality viewport preview of materials? I’d like this to be smooth so I can plan my camera movements accordingly.
    Happy to share more info!
    Matt
    Kouraib Abdmalek
    replied 1 year, 11 months ago
    2 Members · 5 Replies
  • Kouraib Abdmalek
    August 31, 2024 at 6:48 am
    Hi Matt,
    Click on the material then click on Viewport at the top of the material attributes, then change the Texture Preview Size from default to a large size as you want. let me know if this works for you.
  • Matt Rossi
    September 1, 2024 at 12:20 pm
    This worked! The only issue is that the rotation in the viewport doesn’t match the rotation in RS Render View. I have the material projection set to “cubic”.
  • Kouraib Abdmalek
    September 2, 2024 at 9:33 am
    I’m glad you bypassed the texture preview problem, If you are using Primitive Objects make it editable this should make the viewport match the RS render view in the different material projections, let me know if this works.
  • Matt Rossi
    September 3, 2024 at 12:41 pm
    My objects are already editable :/ Happy to provide any other detail
  • Kouraib Abdmalek
    September 3, 2024 at 1:17 pm
    If you could you post your file here, or at least the part related to the texture that will be better.
