Activity › Forums › Maxon Cinema 4D › Redshift/Greyscale Gorilla Material Issue
Posted by John Cuevas on August 21, 2023 at 9:08 pmI cannot figure out why the white material is causing transparency on my objects. If I disconnect the blended Layer 1 Color, this transparency goes away, but I lose some of my texture. If anyone has time to look at this and can tell me what the issue is, that would be awesome, cause I’m about to lose my mind.
John Cuevas replied 3 years ago 2 Members · 8 Replies -
George Charoupas
August 22, 2023 at 7:27 amHello,
Without all the textures, the .c4d file alone isn’t any help.
John Cuevas
August 22, 2023 at 11:00 amYou are right. Feel dumb, I’ve been helping people on the AE forum for 20 years and know all the info is needed, but completely forgot that for my thing.
File with the assets are too big for here, so I posted it to my google drive. Really appreciate you taking a look, cause I’m pulling my hair out trying to figure this out.
https://drive.google.com/file/d/1Y9XvhCdD6vwDNEKevWKPgg5Okg9XNTnc/view?usp=sharing
drive.google.com
Access Google Drive with a Google account (for personal use) or Google Workspace account (for business use).
George Charoupas
August 22, 2023 at 8:44 pmI have requested access twice so far. Having a google drive link with access requests might not be ideal.
John Cuevas
August 22, 2023 at 9:00 pmGave you access and have made the link available to all.
Sorry about that, not my finest linking here.
George Charoupas
August 23, 2023 at 8:15 am -
John Cuevas
August 23, 2023 at 1:01 pmIn your picture, where the splice plate is in the gutter, you can see this double white, where the gutter is behind the splice plate. Then there is the dark stripe where the two gutters don’t connect. That’s the transparency I’m seeing.
George Charoupas
August 23, 2023 at 8:40 pmI tweaked your scene a little bit which (i think) fixed your issue. As I see it, the issue was that the material blender was creating something like an “alpha effect” for super close objects (thats why my plane wasn’t visible, cause it was too far away). I changed the change range node so there are not total black areas and the “alpha effect” is not visible (or better barely visible). The blend color defines the visibility of the layer color.
I hope this fix works for you.
P.S. I am not uploading your textures, cause you already have them.
P.S. 2 I don’t know who made this material but it is super slow to render.
John Cuevas
August 24, 2023 at 1:29 pmThank you George for taking a deep dive into this. I’m an After Effects guy from before it was an Adobe product and been dragged into learning 3D and it’s been a steep learning curve, the first two dimensions are easy, that third one is tricky. Appreciate the explanation too.
The materials were made from the folks at Greyscale Gorilla. I really like them, but even after watching hours and hours of their tutorials, I find tweaking them is a real chore.
