Activity › Forums › Maxon Cinema 4D › /Redshift) Fake proximity shader (via AO) for opacity
  • Boston Cainfra
    January 14, 2023 at 10:37 pm
    The answer is these
    You can try these out since it’s AOV
    Go to AOV dialogue box then change RGB to RGBA and that’s all
    Secondly
    To clearly get what the problem or error is then you should pipe the material to output so that you see the error and correct it
    NOTE- The ramp is piped straight to output
    Now to actually save time of piping the items with a new node editor just solo it using the hot key “S”
