Activity › Forums › Maxon Cinema 4D › Redshift 2.5.48 for Cinema 4D R17.016
  • Redshift 2.5.48 for Cinema 4D R17.016
    Posted by Agnibha Sen on April 8, 2019 at 5:22 pm
    Hi
    I am trying to add the Redshift plugin to my Cinema 4D installation. The Redshift installer recognizes the Cinema 4D installation correctly and installs the plugin files in the proper folder.
    However, the renderer plugin is not showing up in Cinema 4D. The commandline gives an error message –
    Error: plugin (redhsift4c4d-loader.cdl64) doesn’t support the required sdk.
    What’s happening here? I would really be pleased if anyone could help me out with this. Thanks in advance!
    Regards
    Agnibha Sen replied 7 years, 5 months ago 3 Members · 3 Replies
  • Jim Scott
    April 8, 2019 at 8:38 pm
    I would contact Redshift support for help with this issue.
    As an aside, I just saw a news release that Maxon has acquired Redshift.
    https://www.maxon.net/en-us/news/press-releases/article/maxon-acquires-redshift-rendering-technologies/
  • Brian Jones
    April 9, 2019 at 12:10 am
    ah, you’re already there…
  • Agnibha Sen
    April 9, 2019 at 3:48 am
    Okay, thanks! I asked about this issue on the Redshift forums. Let’s see.
    Usually, if the plugin is not showing up on the list of available renderers, then I should update my Nvidia drivers. So currently that’s what I am doing. But if the drivers are not up to date, should the redshift plugin work for Maya 2016 when it is not for C4D? Ugh, I don’t know.
    Let’s see if it works after the update.
