Activity › Forums › Boris FX › Red’s Motion Key Effect Creating *Two* Masks?
  • Red’s Motion Key Effect Creating *Two* Masks?
    Posted by Peter Moretti on May 21, 2012 at 12:21 pm
    I am having an issue with Red’s Motion Key effect where it seems to be using two masks to replace the moving image. This is causing an offset type of distortion.
    I followed this Motion Key tutorial: https://www.youtube.com/watch?v=hJCH8mZeazc&feature=relmfu
    B/c I don’t have the Artbeats source footage, I used some NTSC 720 X 480 footage that I have.
    When I play the effect w/ Remove Area chosen, there is a distortion that seems to be cause by partially overlapping masks.
    I remember seeing this behavior before when using the Motion Key, but didn’t have the time track down the cause. I see this both when using Red as a standalone app or when launched for Avid’s Media Composer.
    The project is set to 720 X 480 NTSC DV. Fields is set to Lower Field. I’m using Windows 7 64-bit and Red version AvidFX 6.0.5.1097.
    The attached images should illustrate what I’m seeing.
    What the effect looks like:
    What the Mask looks like:
    What the Setup Region looks like:
    General settings for the effect:
    Thank you very much for the help!
    Peter Mcauley replied 14 years, 4 months ago 2 Members · 2 Replies
  • Peter Mcauley
    May 22, 2012 at 4:19 pm
    Hi Peter,
    We would very much like to work with you to resolve this – would be be possible for us to use the clip that you are using in the images that you posted? If so, please drop me a note at peterm@borisfx.com and we’ll give it a shot. Assuming that it will work for us, we can then send you the .red project file so that you can see how we did it.
    Cheers,
    Peter.
  • Peter Mcauley
    May 22, 2012 at 9:37 pm
    Hi Peter,
    The problem with this is that you need to feed the motion key filter a stabilized clip – there’s just way too much camera shake in the original shot for the Motion Key to generate a good result. Here’s the workflow:
    • import the clip into RED
    • use the optical stabilizer to stabilize the media
    • render out a new stabilized clip
    • import the stabilized clip into RED
    • use the motion key filter to remove the person
    I’ve sent along a RED project (privately) so that you can see how it’s done.
    Cheers,
    Peter.
