Activity Forums Boris FX RED5 plugin – hang
  • RED5 plugin – hang
    Posted by Guillaume Jeffrey on February 27, 2012 at 1:37 am
    When I do the following, RED5 hangs when I hit “launch UI”.
    1- Apply RED5 as a videoFX on the event – making a Extruded text.
    2- Hit apply and go back to Vegas timeline.
    3- Add a transition on the same event
    4- Use RED5 as transition.
    5- Hit “launch UI”
    Then RED5 opens but there is blank screen, and the program hangs. I need to kill Vegas process to be
    able to conginue.
    Can anybody reproduce this?
    Guillaume Jeffrey replied 14 years, 6 months ago 3 Members · 4 Replies
  • Jeppe Svendsen
    February 27, 2012 at 6:57 am
    I had just the same experience with Media Composer and Avid FX (aka Boris Red) yesterday. I opened my preferences dialog and reset all settings to factory settings. Problem solved.
    Maybe it will help you?
    Jeppe
  • Boris Yamnitsky
    February 27, 2012 at 10:38 am
    We’ve seen the sam problem in our QA labs and we are working with Sony team on a solution. In the meantime, avoid using Boris RED as a filter and as a transition on the same clip. Sorry for inconvenience.
    Boris Yamnitsky
    BorisFX
  • Guillaume Jeffrey
    February 28, 2012 at 2:36 am
    Hi Boris,
    Thanks for your answer.
    I hope you can find a solution soon.
  • Guillaume Jeffrey
    February 29, 2012 at 4:22 am
    Just notice that this only happens when an OpenGL filter is applied as effect whithin RED.
    When no openGL effect, transition and effect can be applied on the same event w/o issue.
