Activity Forums Boris FX RED5 – Importing Picture
  • RED5 – Importing Picture
    Posted by Guillaume Jeffrey on July 31, 2011 at 1:19 am
    I am Using Red5 x64 latest built.
    When I want to import a jpg picture on the timeline, I have the following error:
    “There is not enough memory available to complete the operation. Please make more memory available to the application”
    I have 6gb of RAM and only 25% is used. What can I do?
    Guillaume Jeffrey replied 15 years, 1 month ago 2 Members · 2 Replies
  • Peter Mcauley
    August 1, 2011 at 1:16 pm
    Hmmm … are you running RED standalone or as a plug-in? Are you running a lot of other applications at the same time? What are the pixel dimensions of the image that you are attempting to import? Can you open the image in another image editing application, such as photoshop? If so, try saving it out as a .bmp and see if you can import that image into RED.
    Cheers,
    Peter.
  • Guillaume Jeffrey
    August 2, 2011 at 8:41 am
    Peter,
    I can open the file now. The file path was too long. When I put the image in D:/ no problem to open in in RED.
    BTW, both standalone and Plugin gave me the error message.
