Activity Forums Apple Final Cut Pro Legacy RED with no QT wrapper files
  • RED with no QT wrapper files
    Posted by Eddie Kesler on January 11, 2012 at 11:30 pm
    I received a drive that had two folders of RED footage. One for A-camera and one for B-camera. I used RED Cine-X to transcode the footage to ProRes422 to edit in FCP. A-camera was fine. I tried to load the B-camera into the Bin and apply settings for export, but it says that it “failed to open file” and the thumbnail is black with a red “X” on it. I looked in the folder and the B-camera footage doesn’t have any of the usual 4 QT files inside each clip folder for some reason. Only the raw RED files.
    How can I get those files transcoded without it? Is it possible?
    Why would they be missing?
    Thanks in advance,
    Eddie
    https://www.jamedit.com
    Keetat Tan replied 14 years, 8 months ago 4 Members · 6 Replies
  • David Roth weiss
    January 11, 2012 at 11:39 pm
    If you have the Adobe suite on your FCP machine you can use Adobe Media Encoder to transcode. It’s not as elegant as RED Cine-X, but will do the job.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Eddie Kesler
    January 11, 2012 at 11:45 pm
    Thanks, David. I just tried it and Adobe ME says that “The source file appears to be corrupted. Please check that it is a valid file.”
    Any other ideas??
    Eddie
  • David Roth weiss
    January 11, 2012 at 11:47 pm
    Call the client.
    David Roth Weiss
    Los Angeles
  • Eddie Kesler
    January 11, 2012 at 11:48 pm
    Just did. Wanted to make sure there was no other way first or that I was missing something on my end.
  • Michael Gissing
    January 12, 2012 at 12:07 am
    RED Rushes might work. Obviously the complete file structure wasn’t transferred from the B camera.
    The other possibility is that you can load the R3D files into Color or da Vinci and render out quicktimes in the right codec and frame size but I don’t know if you will lose timecode data doing this. If you are doing a workflow that relinks then that is disaster.
    Searching and askin on the RED forums might also solve this for you.
  • Keetat Tan
    January 12, 2012 at 7:21 am
    Try to update the red Cine x, if I’m not mistaken Red Epic does not come with QT warpper file
