Activity Forums Boris FX RED transition problem
  • RED transition problem
    Posted by Sivan Geyra on October 28, 2011 at 2:13 pm
    I posted this problem at another part of the forum but i might find a better answer here…
    I have a problem with transitional effects while authoring Blu Rays.
    Here is my work flow:
    Final Cut Pro 7
    BORID Red Plugin (for the effects)
    EXPORT SETTINGS: Quicktime Movie – Self Contained
    AUTHORING TOOL: Toast Titanium 11
    Mpeg4 AVC
    Bit Rate: 8-16 mbps
    Motion est: Best, Half PEL
    rest is auto.
    when I play the Blu Ray all of the transitional effects are unsmooth and laggy.
    Any Suggestions?
    Peter Mcauley replied 14 years, 10 months ago 2 Members · 1 Reply
  • Peter Mcauley
    October 28, 2011 at 6:33 pm
    I’m not 100 percent sure of what the cause of this problem may be, but I have a few things to offer for suggestions, some of which you may have already tried but it’s worth a shot.
    • make sure to set the RED transitions / effects to full quality and full resolution before rendering
    • make sure that the timeline is rendered fully and plays back smoothly before going to DVD
    • if you are using apple compressor this might be related to the issue – try doing it bypassing compressor
    • disable opengl setting in RED
    I hope one of these suggestions helps.
    Cheers,
    Peter.
