Activity Forums DaVinci Resolve Red to yellow..?
  • Red to yellow..?
    Posted by Ramesh Jai on January 21, 2012 at 10:41 pm
    A client wants me to change a red colored car to yellow. So after ‘qualifying’ the red color what do I do to change it to yellow..? I’ve tried hue and the color wheels but the closest I get to is brown. Need help please. I’m not a newbie but definitely not an expert either so please be gentle in the explanation. Any advice will be really appreciated. Thanks in advance.
    Knut Jansohn replied 14 years, 7 months ago 4 Members · 3 Replies
  • Stig Olsen
    January 21, 2012 at 11:46 pm
    Desaturate the red first and use the color wheels instead of the hue vs hue. Also, learn some basic about how to make secondary colors with the curves. Horizontal manipulation on the blue curve in this case.
    You can also use the channel mixer.
  • Joseph Owens
    January 22, 2012 at 5:22 pm
    Had a very similar situation a few years ago for a “green” contest, but Honda supplied a RED Prius for the shoot. It took a couple of weeks of rotoscoping to change it to the legal Honda paint chip colour. Depending on the complexity of the shot… specular highlights, motion, dust, reflections, the tail-lights (which you might recall are also red) the color transform is neither simple nor straightforward to achieve at a cinematic quality level.
    Down and dirty? You could try to qualify as much of the car as you can with a node tree (if required) that generates an alpha, then combine that with either a hue vs. hue curve, or an overall hue/phase shift on a parallel node. You may need to generate a travelling matte with a more sophisticated compositing application, because that is what you are doing. Its not, strictly speaking, exclusively a “grading” operation.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Knut Jansohn
    January 23, 2012 at 1:16 pm
    You might count brown as a dark version of yellow 🙂
    So what to do is: simply ad luminance!
    Regards
    Knut
