Activity Forums Apple Final Cut Pro Legacy RED TO – PRO REZ 422 HQ — Data Rate Question
  • RED TO – PRO REZ 422 HQ — Data Rate Question
    Posted by Matthew Rundell on March 26, 2010 at 4:02 pm
    FCP 6.6 (Upgrading to 7 soon for upcoming project)
    Injesting through Log and Transfer. In tests, I’m getting Apple Pro Rez 422 HQ into my machine at a data rate of 26 mbs, the frame size is 2k. I checked a white paper and the data rate for this codec was supposed to be over 200 mbs. Am I wrong here? My R3Ds are fine, shot 4k originals.
    What’s the data rate you guys know about for this codec? Is injest different in FCP 7 in regards to data rate?
    Thanks.
    Matt Rundell
    Matthew Rundell replied 16 years, 6 months ago 2 Members · 2 Replies
  • Rob Grauert
    March 26, 2010 at 5:37 pm
    that should be right.
    8mbps = 1MBps
    so 220mbps = 27.5MBps.
    i think you’re confusing mbps and MBps. mbps is megabits per second, while MBps is megabytes per second. the difference is 8 bits = 1 byte
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Matthew Rundell
    March 26, 2010 at 5:56 pm
    Thanks Robert. Yes, sounds like I was confused. Easy to be with so similar naming conventions.
