Activity Forums Apple Final Cut Pro Legacy red text on black- why so blurry?
  • red text on black- why so blurry?
    Posted by Hamish Lyons on December 8, 2007 at 5:40 pm
    It seems no matter what I try, a red text on a black background always has a blurry edge to it, unless I change the colour which I am not at liberty to do. Has anyone encountered this issue and is there some way of dealing with this?
    Alan Lacey
    replied 18 years, 9 months ago
    7 Members · 6 Replies
  • Tom Wolsky
    December 8, 2007 at 5:54 pm
    What format are you working in? Red is really, really hard to compress. Usually you don’t use red beyond 190-200. If you’re redder than that you’re going to have problems.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Randy Johnson
    December 8, 2007 at 6:32 pm
    have you tryed adding a black stroke to the text?
  • David Roth weiss
    December 8, 2007 at 7:56 pm
    What you’re seeing is DV compression at its worst. If you change the compressor in sequence settings to DVC50, Pro Res, 8-bit or 10-bit uncompressed and re-render you will see a huge difference.
    Test it out to see for yourself, then the proper workflow is to cut everything in the DV timeline and then change the compressor and re-render when you’re completely finished editing so that you’re not having to render constantly when your in the creative stages…
    Make sense???
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Dylan Reeve
    December 8, 2007 at 9:19 pm
    This is probably a DV compression thing… But also, red-black contrast is always a problem with composite video (which is what a lot of people use with the DVD players and VCRs, and is what all analogue broadcasting is) – I can’t remember the specifics, but something about where red is on the spectrum (shortest visible wavelength) and the method of modulation use to encapsulate the luma and chroma signals. I understood it in the lectures, but it’s all escaped me now.
    Basically the end result is that solid red, especially on a solid (or black) background is never a great idea with video. However with less saturation the problems are less pronounced.
  • David Fortin
    December 8, 2007 at 10:01 pm
    If my long term memory is any good, I remember something from the TV 101 lectures in college about the three colors that make up the video signal Green, Blue and Red. And that out of the three, red has the least amount of information in the signal, so red is the worse reproducible (if that’s a word) color.
    I think you’ll have trouble no matter what compression you use. If you have ever rented a movie that has red credits over black, they look nice and crisp in the theater, but when you watch it at home on DVD, you can barely even read it.
    Dual 2.5 G5 {OS 10.4.9}
    4.5 GB RAM
    FCP2
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    Media Cleaner Pro 6
    AfterEffects 7
    Squeeze 4.2 (PC)
    ViewSonic 19″ LCD
    Optiquest 21″ CRT
    Bella EZ Keyboard
  • Alan Lacey
    December 8, 2007 at 10:06 pm
    Saturated red is very low luminance level and with composite, Y/C and YUV it’s only the luminance channel that has greater bandwidth.
    What you’re seeing is the lower bandwidth quality of the chroma channels. Increase the red luma somehow – ie desaturate.
    Even going uncompressed (YUV) saturated reds will have less ‘sharpness’ than white, greys or blacks.
    Alan
