Activity Forums Apple Final Cut Pro Legacy Red screen of death?
  • Red screen of death?
    Posted by Bret Williams on July 1, 2005 at 8:54 pm
    The canvas went red and said I’d have to close the window and reopen to get display back. Upon trying that, that particular seqeunce will no longer open. It first says “operation not allowed” then after clicking ok, it says “error out of memory.”
    So I’ve rebooted, and trashed prefs, but nothing changes. In autosave vault I had to go back several hours to get a version that would open that sequence. And I did a lot of work in those 3 hours.
    Any ideas?
    Version 4.5, G4 350, All DV setup with DSR-20, external FW.
    Jerry Hofmann replied 20 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 4, 2005 at 1:55 pm
    In the Canvas, select RGB as the viewing option. It’s set to Alpha sounds like…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
