Activity Forums Apple Final Cut Pro Legacy RED R3D files, transcoding & FCP workflow
  • RED R3D files, transcoding & FCP workflow
    Posted by Edward Koehler on July 5, 2010 at 4:45 pm
    Hello. I’m a relative newbie. I’ve searched and read the previous posts but I haven’t found an answer to my issue. Please forgive me if this has been addressed before.
    I have a client with a music video shot on Red. The problem I’m having is that the footage has arrived to me on a LaCie rugged drive with the raw R3D files appearing in a folder called ‘Online’, but there are no .rdm subfolders, or .rfc or .profile items as described in the FCP workflow here- https://documentation.apple.com/en/finalcutpro/professionalformatsandworkflows/index.html#chapter=11%26section=3
    I believe the files were prepared for use in Premiere before I received them.
    So, now I’m a little confused and I’m trying to see my way onto the recommended workflow for FCP. From my FCP it will go to Assimilate Scratch for grading at 4K, I believe.
    I’m currently copying the entire contents of ‘Online’ folder to my G-Raid2 1.5TB FW800 external drive, and then I plan to transcode to ProRes422(HQ) via RedAlert and then work with _M.mov or possibly _H.mov on the FCP timeline, although the Scratch grading tech has recommended that I work with the _P.mov files. Which quality would be best to work with?
    I’ve downloaded and installed RED FCS2 Installer, RedAlert and Redcode Quicktime codec.
    Am I headed in the right direction? I’ve read about corruption issues and to never rename any of the files. Do I need the .rdm subfolders, the .rdc and .profile items because I don’t see them.
    2 x 2.26GHz Quad-core Intel’09 MacPro / 8GB ram / OS X 10.5 / Black Magic Decklink HD extreme 3 / G-Raid2 1.5TB FW800 / Final Cut Studio 2 / Final Cut Pro 6
    Edward Koehler replied 16 years, 2 months ago 1 Member · 1 Reply
  • Edward Koehler
    July 8, 2010 at 3:22 am
    Thought I’d update this in case anyone else has the same question.
    It doesn’t seem to matter that the .rdm subfolders, .rfc and .profile items are missing. I simply copied all the R3Ds into a new folder on my external drive. From there, I made _p.mov quicktime proxies using REDAlert. After import, drag them to a ProRes sequence and render.
    I attempted working in a REDCODE sequence, but this was causing serious scaling on the slo-mo footage, and I was unable to add any basic effects (the entire clip would grey-out after render).
    I imagine I wouldn’t have to render as much if I’d transcoded to ProRes, but it’s a bit late for that now and the _p.mov proxies seem to be working fine otherwise.
    Hope that helps someone!
