Activity Forums Adobe Premiere Pro RED proxies in Premiere Pro
  • RED proxies in Premiere Pro
    Posted by Lisa Olshanski on April 25, 2021 at 10:33 pm
    Hi All! I’m editing with Premiere Pro v15 on a MacBook Pro 2019, 2.3GHZ 8 Core i9 Processor with 32 GB memory. I received 8K RED footage and made Pro Res 422 1920×1080 proxies to work with but my sequence is all stuttery so I cannot edit. This occurs even after I render the whole sequence. I’m definitely editing with the proxy files since I took the original media offline. Why would this sequence not be playing? Please help!
    Eric Santiago replied 5 years, 4 months ago 2 Members · 3 Replies
  • Eric Santiago
    April 26, 2021 at 2:35 am
    Where did you create your proxies?
    Within Premiere?
    Where are the footies during the editorial?
    My only experience working with 8K RED is in FCPX proxied to ProRes.
    A few features and honestly I gave up using a laptop after a few days.
    Mostly done in a 2013 MP D700 w64GB.
    Not the answer you’re looking for wish you luck.
  • Lisa Olshanski
    May 3, 2021 at 2:21 pm
    I created the proxies from Premiere. I’m working from an external SSD. I moved to an iMac and it was fine. Not sure why my laptop cannot handle it.
  • Eric Santiago
    May 4, 2021 at 1:09 pm
    There is no way I can do any of this on a local drive so where are your files living?
    What kind of external SSD?
    Anytime I use a Mac laptop for DIT, I make sure to have the fastest possible drive setups.
    Basically, with mine, it’s Thunderbolt 2 using a Sonnet PCI (SSDs) box.
    It’s an old 2015 MBP so all the help I can get.
