Activity Forums VEGAS Pro Red preview hang in Vegas Pro 15
  • Red preview hang in Vegas Pro 15
    Posted by Michael Hoogasian on December 28, 2018 at 7:36 pm
    I just upgraded to Vegas Pro 15 from Movie Studio 12, and I’m having a perplexing problem: while playing around with some of my previous project files, the preview pane will turn red and Vegas will hang and I have to force quit it from Task Manager. I’ve done some googling, and apparently a red screen means Vegas ran out of resources, but all those threads are from like 2012 when people were still on 32-bit OSes…. Help?
    System specs:
    Vegas version: 15.0 (build 416)
    CPU: AMD FX-6300
    RAM: 24GB
    GPU: Nvidia GTX650
    OS: Win7 x64
    George Dean replied 7 years, 6 months ago 2 Members · 14 Replies
  • 14 Replies
  • George Dean
    December 28, 2018 at 9:54 pm
    Hi Michael, have you tried to turn off ‘GPU acceleration of video processing’ in ‘Options’, ‘Preferences’, ‘Video’ tab?
    Can you post the specs of your source media in those old projects that are causing the red screen? Use ‘Mediainfo’ in ‘Text’ mode to post the results.
    Best Regards……George
  • Michael Hoogasian
    December 29, 2018 at 5:21 pm
    Hi George,
    No, I haven’t tried that, but I will ☺
    Here’s the output for the file types used in the project:
    File 1:
    General
    Complete name : *****.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/3gp4)
    File size : 7.58 MiB
    Duration : 28 s 743 ms
    Overall bit rate : 2 211 kb/s
    Encoded date : UTC 2015-12-26 21:31:35
    Tagged date : UTC 2015-12-26 21:31:35
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Baseline@L3.2
    Format settings : 1 Ref Frames
    Format settings, CABAC : No
    Format settings, RefFrames : 1 frame
    Muxing mode : Container profile=High@1.3
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate : 2 208 kb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 22.440 FPS
    Minimum frame rate : 0.147 FPS
    Maximum frame rate : 88.496 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.107
    Stream size : 7.57 MiB (100%)
    Title : VideoHandle
    Language : English
    mdhd_Duration : 28743
    Codec configuration box : avcC
    File 2:
    General
    Complete name : ****.mp4
    Format : MPEG-4
    Codec ID : isom (isom/avc1/mp42)
    File size : 31.9 MiB
    Duration : 15 s 48 ms
    Overall bit rate : 17.8 Mb/s
    Encoded date : UTC 2014-10-17 15:08:54
    Tagged date : UTC 2014-10-17 15:08:54
    Video
    Format : AVC
    Format profile : Baseline@L4
    Format settings : 3 Ref Frames
    Format settings, RefFrames : 3 frames
    Codec ID : avc1
    Bit rate : 17.8 Mb/s
    Maximum bit rate : 106 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.286
    Stream size : 31.9 MiB (100%)
    Writing library : Zencoder Video Encoding System
    Encoded date : UTC 2014-10-17 15:08:39
    File 3:
    General
    Format : MPEG-4
    File size : 17.9 MiB
    Duration : 10 s 977 ms
    Overall bit rate : 13.7 Mb/s
    Encoded date : UTC 2014-10-17 15:44:21
    Tagged date : UTC 2014-10-17 15:44:21
    Video
    Format : AVC
    Codec ID : avc1
    Bit rate : 13.7 Mb/s
    Maximum bit rate : 25.8 Mb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.220
    Stream size : 17.9 MiB (100%)
    Encoded date : UTC 2014-10-17 15:44:13
    File 4:
    General
    Format : MPEG-4
    File size : 30.2 MiB
    Duration : 21 s 353 ms
    Overall bit rate : 11.9 Mb/s
    Encoded date : UTC 2014-10-16 20:29:05
    Tagged date : UTC 2014-10-16 20:29:05
    Video
    Format : AVC
    Format settings, GOP : N=1
    Codec ID : avc1
    Bit rate : 11.9 Mb/s
    Maximum bit rate : 33.7 Mb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.191
    Stream size : 30.2 MiB (100%)
    Encoded date : UTC 2014-10-16 20:28:46
    File 5:
    General
    Complete name : ****.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2007.09 (qt /CAEP)
    File size : 23.7 MiB
    Duration : 7 s 941 ms
    Overall bit rate : 25.1 Mb/s
    Encoded date : UTC 2015-12-26 21:08:56
    Tagged date : UTC 2015-12-26 21:08:56
    Copyright : N/A
    com.apple.quicktime.make : Canon
    com.apple.quicktime.model : Canon PowerShot SX50 HS
    com.apple.quicktime.author : Michael Hoogasian
    Video
    Format : AVC
    Format profile : Baseline@L4.1
    Format settings, GOP : M=1, N=15
    Codec ID : avc1
    Bit rate : 23.4 Mb/s
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.849
    Stream size : 22.2 MiB (93%)
    Language : English
    Color range : Full
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : sowt
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 1.45 MiB (6%)
    Language : English
    File 6:
    General
    Complete name :****.mp4
    Format : MPEG-4
    File size : 14.9 MiB
    Duration : 10 s 10 ms
    Overall bit rate : 12.5 Mb/s
    Encoded date : UTC 2016-05-18 07:56:06
    Tagged date : UTC 2016-05-18 07:56:06
    Video
    Format : AVC
    Codec ID : avc1
    Bit rate : 12.5 Mb/s
    Maximum bit rate : 15.6 Mb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.201
    Stream size : 14.9 MiB (100%)
    Encoded date : UTC 2016-05-18 07:56:03
    Color range : Limited
  • George Dean
    December 29, 2018 at 6:22 pm
    Hi Michael,
    I suspicious of ‘File 1’. This is what I would do as a quick experiment…..Start Vegas and load the ‘problem’ project. Make sure ‘Auto-Ripple’ is turned off. Then remove all the events on any of the tracks of ‘File 1’. Remove ‘File 1’ from the ‘Project Media’ bin. Of course every place that ‘File 1’ was on a track is going to be black now, but that is OK for this test. Then save this project with a different name such as simply ‘Temp Test’. Close the project and shut down Vegas, start Vegas and load the new project ‘Temp Test’. If this project acts normal, we have narrowed it down to ‘File 1’.
    ‘File 1’ is ‘Variable Frame Rate’ and Vegas often doesn’t like variable frame rate source media. If this is the case, there are ways to get around this, but first we need to determine if ‘File 1’ is the cause. Even though a previous version of Vegas had no problem with this variable frame rate file, doesn’t mean that Vegas Pro 15 will not, and this test should quickly determine that.
  • Michael Hoogasian
    December 30, 2018 at 2:24 am
    Hmmm OK. Should I test it with or without GPU accel? Probably with so as to limit the variables?
    Also, sometimes when closing Vegas while nothing is open, it crashes – which makes no sense at all…..
  • George Dean
    December 30, 2018 at 3:35 pm
    I would test it with whichever and if no success, try the other way. Once in a while I get the crash on closing as well. As I was done with the project at that point, I never pursued why.
  • Michael Hoogasian
    January 2, 2019 at 9:57 pm
    Ok, will do. FYI It may be a few days before I’m able to test.
  • Michael Hoogasian
    January 23, 2019 at 3:05 pm
    I’m so sorry it has taken me so long to get back to you, I’ve just been really busy ☹
    So, as stupid as this is, when I tried to perform organized tests to isolate the problem, I couldn’t reproduce it anymore!
    However, today something even stranger than the red screen & hang happened: a red screen without a hang. There was only one file in the project at the time, and literally the only thing I had done was drag it onto the timeline, sleep the computer, and then when I woke it back up Vegas was showing the red preview screen without having hung.
    Here’s the media info for that one file:
    General
    Complete name : *****.MP4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp41/mp42/isom)
    File size : 165 MiB
    Duration : 2 min 48 s
    Overall bit rate : 8 217 kb/s
    Encoded date : UTC 2018-03-17 19:23:04
    Tagged date : UTC 2018-03-17 19:27:02
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings : CABAC / 1 Ref Frames
    Format settings, CABAC : Yes
    Format settings, GOP : M=1, N=30
    Codec ID : avc1
    Bit rate : 8 091 kb/s
    Height : 720 pixels
    Frame rate : 29.970 (29970/1000) FPS
    Minimum frame rate : 28.571 FPS
    Maximum frame rate : 30.000 FPS
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.293
    Stream size : 162 MiB (98%)
    Title : Core Media Video
    Encoded date : UTC 2018-03-17 19:23:05
    Color range : Full
    Matrix coefficients : BT.601
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Source duration : 2 min 48 s
    Bit rate : 128 kb/s
    Channel(s) : 1 channel
    Channel layout : C
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 2.52 MiB (2%)
    Source stream size : 2.52 MiB (2%)
    Title : Core Media Audio
  • George Dean
    January 23, 2019 at 6:10 pm
    Hi Michael,
    If you start a new project and import only this file, does it work OK or do you get the red preview? I would turn off sleep mode, as that may disconnect some of the resources Vegas needs. If this problem file will load and preview normally, I would render it out using a render format something like Sony XAVC Long (it will be a large file) and then bring that into your original project replacing the original problem file.
  • Michael Hoogasian
    January 23, 2019 at 9:57 pm
    [George Dean] ” I would turn off sleep mode, as that may disconnect some of the resources Vegas needs”
    Well, that’s not really an option for me as I daily use sleep mode because I keep a lot of things open and I don’t want to leave my computer on 24×7. Besides, Vegas really shouldn’t have any problem with sleep mode – sleep mode keeps everything in RAM. I’ve written a few desktop programs and Android applications, and I literally had to do NOTHING to ensure compatibility with sleep. It would be utterly disgraceful if the Vegas software engineers didn’t bother to test their software to make sure it works with sleep mode.
  • George Dean
    January 25, 2019 at 6:01 pm
    Hi Michael,
    Have you been able to repeat the red screen since your last reply?
