Activity › Forums › Apple Final Cut Pro Legacy › Red on chapter markers FCP 6
  • Red on chapter markers FCP 6
    Posted by Andy Crowson on December 29, 2013 at 10:53 pm
    Really basic this, I’m sure, but I can’t figure it out.
    Using FCP 6 and when I add chapter markers to one particular sequence, and the playhead is on the marker, the right-hand side of the green marker is red. Can’t find anything in the literature (‘though I’m sure it must be there) – what does it actually mean? It’s not appearing in any of the other sequences I add chapters to.
    Andy
    John Fishback
    replied 12 years, 9 months ago
    2 Members · 3 Replies
  • John Fishback
    December 31, 2013 at 7:23 pm
    Zoom in and see if, perhaps, you have 2 markers at the same time. I don’t think having two colors affects anything. You can color markers any way you wish. Although, it is strange if a single marker has two colors.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Andy Crowson
    December 31, 2013 at 9:58 pm
    Definitely not two markers. Only on this one sequence. The red mark appears when I insert a marker, and disappears when I remove the playhead, but reappears when I replace the playhead on the marker. Bizarre. FCP 6.
    See image below…
    Andy
  • John Fishback
    December 31, 2013 at 10:08 pm
    Quite strange, I agree. I’m mostly using FCPX now, but I don’t recall ever seeing this with FCP since v4.
    John
