Activity Forums Apple Final Cut Pro Legacy RED Log and Transfer Plug-in is cutting clips short
  • RED Log and Transfer Plug-in is cutting clips short
    Posted by Danny Macdonald on May 26, 2013 at 6:18 am
    I’m trying to ingest several cards of RED footage using the FCP log and transfer plug-in however after the clips appear in my capture scratch I am finding that several of the clips are shorter than their original durations, some even only a couple seconds long.
    Within the log and transfer window the clips show the correct duration and I can even scrub through the entire clip in the log and transfer’s clip (proxy) viewer. It is only after the transfer is complete that the captured clip is shorter in duration.
    Any suggestions to why this is happening would be greatly appreciated.
    Daniel Sametz replied 13 years, 3 months ago 2 Members · 3 Replies
  • Daniel Sametz
    May 26, 2013 at 7:43 pm
    It had happened to me several times with 5D footage because I was using the program while it did the L&T. The solution is that I don’t use it now and it stop happening, don’t save, cut, rename or anything.
  • Danny Macdonald
    May 26, 2013 at 11:38 pm
    Ah, it looks like that was my problem too. Thanks!
  • Daniel Sametz
    May 27, 2013 at 4:38 pm
    Glad I could help 😀
