Activity › Forums › Apple Final Cut Pro Legacy › Red line on DV material
  • Red line on DV material
    Posted by Chet Lauritsen on April 25, 2007 at 3:21 pm
    I am new to FCP, and can not seem to figure out why, when I have DV-25 clips in my project that will play back just fine in the viewer, has to be rendered when put on the timeline.
    The material was shot on beta, digitized in Avid Adrenaline 1:1, and exported out as Quicktime movies with the Avid DV25 codec.
    The files are all on an external firewire drive and imported into FCP 4.5. I know that the sequence settings have to match the footage, so I have tried several different settings with no luck. Doing apple-I on the clips tell me that they are 720×486, and I have tried to set my FCP sequence to that as well, but still no.
    What am I doing wrong here? Thanks.
    G4-500
    1GB Ram
    FCP 4.5
    External Firewire.
    Chet L
    David Battistella replied 19 years, 5 months ago 2 Members · 3 Replies
  • David Battistella
    April 25, 2007 at 3:27 pm
    Easy set up> DV NTSC
    Make a new sequence and things should be fine.
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
  • Chet Lauritsen
    April 25, 2007 at 3:35 pm
    Thanks, David.
    I am pretty sure I tried that already, but I’ll try it again and get back to you. If that doesn’t work, however, what other issues might be at work here?
    Chet L
  • David Battistella
    April 25, 2007 at 3:40 pm
    You need to be sure that your sequence settings and footage setting are perfectly matched. IF the:
    FRAMERAE
    SIZE
    COMPRESSION
    differ in any way then you will have the red bar all day .
    David
    Peace and Love 🙂
    Read my Blog
