Activity Forums Boris FX Particle Illusion Red Lightning
  • Posted by Mark Mora on January 20, 2010 at 2:51 am
    In one of the emitter libraries for 2009, for August, their is an emitter called Lightning Strike. Is there a way to make the lightning red? I went to the emitter properties and changed the tint and color, but it only changes the color of the sparks.
    Kurt Muller replied 16 years, 8 months ago 2 Members · 1 Reply
  • Kurt Muller
    January 20, 2010 at 9:52 am
    Mark, first, add your emitter to the stage, then open Properties. Don’t touch the “tint” tab, just click on the Particles tab, and then click on the “colors” tab.
    The bar at the bottom shows the “color over life” of the emitter. Click on one of the sliders, and then click on the color wheel and select the color you want. You may have to click on every silder and change the color each time until the total emitter color is what you want.
    Important to do this after you’ve added the emitter to the stage. That way, when you click on “add to library”, you can save your modified emitter in its new colors, without overwriting the original emitter.
    Kurt.
