Activity › Forums › Boris FX › Red Light Wipe
  • Red Light Wipe
    Posted by Peter Tours on August 23, 2010 at 10:38 am
    I went looking for the light wipe I have used a lot in earlier versions but cannot find it. Has it been renamed? Or is it gone? It;s a nice easy fx and clients like it. Is it stil in 4.3.4 somewhere?
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    Peter Tours replied 16 years, 1 month ago 2 Members · 9 Replies
  • 9 Replies
  • Peter Mcauley
    August 24, 2010 at 12:48 pm
    Hi Peter,
    Do you recall the exact name of the wipe effect?
    Peter.
  • Peter Tours
    August 24, 2010 at 1:25 pm
    Hi Peter – I think it was called “Light Wipe” and lived in the wipes section. YOu could do a “laser from one end to another, wipe to and from center (or positionable) with doors or a circle pattern choosable.
    Peter Tours
    Fort Lauderdale, FL
  • Peter Mcauley
    August 24, 2010 at 1:46 pm
    I think I found it – can you try this one:
    RED 4.0 Keyframe Library/Transitions/Filter-mix Transitions/Lightsweep Wipe.red
    Is this is the one you are searching for?
    Cheers,
    Peter.
  • Peter Tours
    August 24, 2010 at 2:05 pm
    Sorry, no. I wish I still had a copy of 2.53 so I could show you. I believe it was called light wipe or light wedge or wedge wipe…
    Peter Tours
    Fort Lauderdale, FL
  • Peter Mcauley
    August 24, 2010 at 3:45 pm
    Hmmm … I’m really not sure exactly what the effect looks like but if you have an old render example that you can send me I can help you replicate the look and create a new settings file for your library.
    Cheers,
    Peter.
  • Peter Tours
    August 24, 2010 at 7:25 pm
    I sent an email to support@borisfx.com with the clip. Please check out how the logo is effected on – that’s the wipe, but it does so much more.
    Peter Tours
    Fort Lauderdale, FL
  • Peter Mcauley
    August 25, 2010 at 1:12 pm
    Hi Peter,
    Thanks for sending that in – I’ll check with support.
    Cheers,
    Peter.
  • Peter Tours
    August 27, 2010 at 1:49 pm
    I just sent you that clip – sorry it took so long. Got distracted….thanks in any help tracking down the wipe!
    Peter Tours
    Fort Lauderdale, FL
  • Peter Tours
    August 28, 2010 at 3:46 am
    Found! My bad – it was an FEC plugin. Didn’t realize it was a separate product at the time.
    Peter Tours
    Fort Lauderdale, FL
