Activity › Forums › Adobe After Effects › Red Laser pointer removal
Posted by Dane Silzle on March 20, 2011 at 1:27 amDoes anyone have experience with removing a red laser pointer (or it equal) from
tlive footage? and how would you go about rotoing it out.This laser pointer was used by the trainer to get the cat to pat the dog on the head and it’s moving all over the footage. Please see the frame grab:
I’m still working with CS3,
Thanks for your help,
Dane
Dane Silzle replied 15 years, 5 months ago 4 Members · 9 Replies -
Tudor “ted” jelescu
March 20, 2011 at 10:17 amIt’s not an easy task- not seeing the footage it’s impossible to say for sure, but I presume that the laser pointer goes over different textures which requires you to deal with it in segments. First animate a mask around the point with room enough to feather the edges. Then comp the footage on top of itself. Now you will have to animate an offset on the footage below to match the texture under the hole left by the mask. This way you will get the same texture, color, grain and even movement
Tudor “Ted” Jelescu
Senior VFX Artist -
Dane Silzle
March 21, 2011 at 11:56 pmTed,
Thank you so much for you rapid and helpful response, I apologize for not responding sooner.
I was out with another client on a production over the weekend and just got back to the studio.Ordinarily, we’d have control of the Takes when at a shoot, however this was actually a Photo Shoot
for Print and the Agency asked us to Shoot “B-Roll”(their term for: get what you can and we’ll make something out of it). Unfortunately there was no opportunity to control the shoot.I’ve been considering Mocha Pro for the Planar tracking and removal, do you think it would help
with this fast moving Laser pointer?Thanks again Ted
Regards, Dane -
Dane Silzle
March 22, 2011 at 12:03 amDave,
Please read my (above) response to Ted, It’s important you have all the facts before
posting a hasty response… -
Tudor “ted” jelescu
March 22, 2011 at 7:26 amNot being able to see your footage it makes it hard to say- my gut feeling is that the laser point may be moving too fast for any tracking to be of use, that’s why I suggested the method in my initial post.
Tudor “Ted” Jelescu
Senior VFX Artist -
Dane Silzle
March 22, 2011 at 7:08 pmThanks Ted,
When the agency decided what direction we’re going with on this prodject,
I’ll try your fix and report back.Dane
Ross Shain
March 22, 2011 at 9:54 pmHi Dane,
If the clean frames exist within the shot, there is a good chance that mocha Pro could help. If the area you want to remove goes over very specific moving details it could make it a lot trickier.If you’d like to post the footage our team can usually tell very quickly if mocha Pro will help or not.
Best,
Ross Shain
Imaginer SystemsRoss Shain
Imagineer Systems
http://www.imagineersystems.com -
Daniel Power
March 28, 2011 at 3:15 pmLaser beam is bad for your eyes,I think you’d better find a expert to do it.
Dane Silzle
March 28, 2011 at 4:18 pmThe professional Trainer was using the clicker and pointer.
There Cats and dog from there facility. I’m sure they know what their doing
as these trainers have featured on numerous major movie released. -
Dane Silzle
March 28, 2011 at 4:24 pmhe professional Trainer was using the clicker and pointer.
