Activity › Forums › Adobe Premiere Pro › RED in new CC 2015
RED in new CC 2015
Posted by Lance Bachelder on June 16, 2015 at 4:50 pmWhy is the “Source Settings” for Red footage selection now greyed out in Premiere? I’m sure it’s user error…
It was at a Vegas premiere that I resolved to become an avid FCPX user.
Lance Bachelder
Writer, Editor, Director
Downtown Long Beach, California
https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1Richard Li replied 10 years, 10 months ago 12 Members · 19 Replies -
Trent Happel
June 16, 2015 at 5:11 pmSource Settings are now Master Clip Effects.
Around 26:10 in following video:
https://www.youtube.com/watch?v=O1clWi4hta4&feature=youtu.be&t=1569Trent Happel
Adobe
Premiere ProSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Kevin Monahan
June 16, 2015 at 5:58 pmYes, Source Settings are now an intrinsic (built in) effect located in the Effect Controls panel. A bit confusing the first time you try it.
Kevin -
Lance Moody
June 17, 2015 at 1:57 amThat works with Red footage but no such effect with Sony raw? Is that correct?
Lance
Trent Happel
June 17, 2015 at 2:38 amShould be any format that previously had Source Settings, is now moved to Master Clip Effects. This should include Sony RAW. Just checked a clip and it was now under Master Clip Effect in CC 2015 (9.0)
Trent Happel
Adobe
Premiere Pro -
Aaron Russell
June 18, 2015 at 4:13 amI’m not having any luck – R3D file in the timeline > and when I click on the Master Clip effects (as shown in the video above in this thread) nothing is there! Nada!
Trent Happel
June 18, 2015 at 4:39 amIs this with a new CC 2015 (9.0) Project or using a previous version Project (e.g.: CC 2014 8.2)? In the case of previous version Projects with RED media, it will still use Source Settings (for compatibility). The change to Master Clip Effect is only with new CC 2015 (9.0) Projects.
Trent Happel
Adobe
Premiere Pro -
David Braman
June 24, 2015 at 3:37 pmThe problem with this structure is that in the past you could select multiple takes; select “source settings”; make your adjustments; and they would be applied to all the highlighted clips. Now it seems the best you can do is copy the adjustments, then paste it, one clip at a time…after you’ve put it into the sequence. I don’t get why this was necessary. Didn’t add any functionality and it makes the workflow much less streamlined. I liked being able to care of all the RAW work at once.
Dave Adams
June 29, 2015 at 6:41 pmWhat if the project was started on 8.0 and you are now in 9.0? I don’t see source option or master clip option.
Dave
Gavin Fisher
July 14, 2015 at 8:23 pmif you right click on “red source settings” in the effects tab and copy, you can then select multiple clips in the bin and paste.
another cool feature is you can now write your settings to the RMD so they carry over to resolve. however, i haven’t found a way to write to multiple RMD’s at once. seems like a one-at-a-time process…
Ben Nelson
September 18, 2015 at 2:16 amI still can’t seem to find where this effect is in the effect toolbar
