Activity Forums Adobe Premiere Pro RED Importer plug-in for CS4
  • RED Importer plug-in for CS4
    Posted by James Brady on June 1, 2009 at 9:22 pm
    Is anybody currently using the RED importer plug-in ( REDCODE CS4 Win 1.7 ) for Adobe Premiere Pro CS4? I have been trying to install it on the following machine with no luck:
    System:
    Windows Vista Ultimate 64-bit SP1
    Dual Quad Core 3GHz processors
    16GB RAM
    CalDigit 2TB SATA RAID
    Pr CS4 v4.1.0)
    AE CS4 v9.0.2.42)
    All are the latest installs… Adobe updated first, then installed REDCODE. The installer appears to work (shows in the control panel as an installed program), but I still get no RED sequence options in Premiere and R3D files are an “unsupported format”.
    The same download of REDCODE installed and operates perfectly on a different workstation (WindowsXP), but the above system is the one it needs to be on. Any ideas?
    Best,
    James
    James Brady
    Senior Editor
    Results Video & Animation
    El Paso, Texas
    http://www.resultsvideo.com
    James Brady replied 16 years, 5 months ago 2 Members · 4 Replies
  • Luis Antonio guerra
    April 16, 2010 at 5:39 am
    could you solve the problem? I’m having the same issue running on Widnows 7 64bit, what could be happening?
  • James Brady
    April 16, 2010 at 3:37 pm
    I’ve still not got it to work on the Windows Vista system. My best guess is that it has something to do with Vista/Windows 7 or 64-bit incompatibility.
    James Brady
    Senior Editor
    El Paso, Texas
    April 16, 2010 at 4:54 pm
    Afer reading thousands of posts and trying lots of methods I came witha solution: download Universal Extractor (the first site on google) and extract the redcode .msi installer using the default method. UE will create a folder next to the msi with all the files, then just copy the presets folder ino the Settings\SequencePresets folder and files “ImporterRED.prm” and “ImporterREDServer.exe” inside the Adobe\Common\Plug-ins\CS4\MediaCore folder in Program files (x86)
    Reboot and that’s it. (a friend of mine told that perhaps double clicking on the installer first was necessary because it may had installed some dlls or added some registry keys which cannot be done by using this “manual instalation” method)
  • James Brady
    April 19, 2010 at 3:28 pm
    Luis,
    This worked! The extraction & manual installation of the RED importer plugin is the way to go. RED sequence presets now show up in Premiere and R3D files import just fine with full control over clip source settings. Very nice footwork, Luis! Thank you for sharing.
    Interestingly, I’ve had to manually install other software updates on the same system. The root of this problem may still have something to do with Vista/Win7 security settings… but manually installing is a nice enough workaround for now!
    Best,
    James Brady
    Senior Editor
    El Paso, Texas
