Forums › Adobe After Effects › Red Giant Trapcode Form – Object jumps around screen and won’t stay in center
Frank Sigwarth
January 15, 2021 at 7:16 pmHi everyone,
I’m working with Red Giant’s Trapcode Form and have created an energy ball that I’m using in my animation. Without having any keyframes or anything that would cause it to, the energy ball flash from the center to another part of the screen and sometimes flicker between the two positions.
I’ve tried changing rendering with the CPU vs GPU, changing the color bit depth, the comp resolution, and managed to get a workable section where it’s not moving for long enough that I can use it, but now I want to tweak some of the settings and each time I change one of them (Particles in X F3, Particles in Y F3) I have the same issue as before.
Anything I can do to fix this bug?
Running AE 2020 (17.5.1)
MacOS Mojave v10.14.6
imac pro 2017
process 3GHz Intel Xeon W
Memory: 64 GB 2666 MHz DDR4
Graphics Radeon Pro Vega 56 8 GB
Log in to reply.
