Activity Forums Adobe After Effects Red Giant Planespace Box Creator issue
  • Red Giant Planespace Box Creator issue
    Posted by David Bitterman on August 19, 2014 at 7:58 pm
    Anyone run into a problem with planespace box creator only making an exploded box? Anytime I enable the options with any settings, including scale to fit, with six layers of 100×100 perfect squares (or using a single side and the repeat option), I get an exploded box of large proportions regardless of my settings. If I go to user defined size it won’t let me put anything in smaller than about 500 or so (which seems to create the same exploded box look), even though all my sides are 100×100 (I get some error saying the user defined size must be greater than or equal to the largest layer size, which it is and then some.
    I’ve experimented with the other planespace creator tools and they all seem to work besides the box creator. Any and all help is much appreciated!
    David Bitterman replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
