Activity › Forums › Adobe Premiere Pro › Red Giant Colorista II with CS5.5
David Robillard replied 12 years, 1 month ago 6 Members · 16 Replies
Erik Naso
July 12, 2011 at 3:07 pm[Tim Kolb] “I’m not sure that expecting a 64 bit program designed and released in 2011 to read the third party hardware settings from a 32 bit program with only minor structural changes since 2007 (when Adobe was current as CS3 with no multiple sequence settings within a single project) is a realistic expectation.
I understand that Premiere Pro loading FCP projects is hugely helpful for FCP users who have decided they need to migrate, but Adobe has had 4 drops (CS3, CS4, CS5, CS5.5) since FCP was last really structurally upgraded. (Apple did not really present the 2009 changes as a major version upgrade and most of my colleagues who used FCP didn’t think of it that way either…)
PPro does some things differently than FCP…that’s a given.”
I dont have unreal expectations only a thirst for knowledge, and how I can work with and get Ppro to work best for me.
If I could change the sequence settings from the XML FCP imported project I would be good to go, but they’re grayed out. By copying the clips to a new sequence that solved the problem. If there is a easier way I’m all ears. Thanks Tim.Blog https://www.eriknaso.com
My Vimeo Page https://vimeo.com/user626030
Follow me on Twitter @ErikNaso -
Erik Naso
July 12, 2011 at 3:19 pm[alex schwindt] “So let me make sure I’m understanding this right – does Colorista II work in Premiere Pro CS5.5? Specifically on a Mac?
I’m in a similar position as Erik in that I need to find an NLE solution in this new post-FCP world, but Colorista II is a HUGE part of my workflow. I want Premiere Pro CS5.5 to be my solution moving forward, but if Colorista II doesn’t work that’s going to be a huge problem.
Can anyone address this???”
Red Giant seems to not have Colorista II as a single download. Its in the Magic Bullet Suite so I had to download the trial version of the suite. That gave me version 1.0.2 of Colorista II
I unistalled Colorista II and launched the Magic Bullet Suite installer. Now the option for Premiere Pro CS5.5 appears.
After installing I rebooted the Mac then launched Ppro. Much better now. No more blinking previews and for the most part much more responsive. Dynamic update to AJA out is much better. I find that Colorista II works better in the Color Correction workspace.I have clip in Program and Waveform in Reference all updating adjustments in realtime.
Tonight I will be spending a few hours doing CC so for now it looks promising.Blog https://www.eriknaso.com
Tim Kolb
July 12, 2011 at 3:24 pmI guess what I’m saying is that importing an FCP project and altering its settings are two different animals entirely. PPro doesn’t alter the settings on PPro sequences…
The workflow in PPro is to create another sequence if you need to alter framerate/size settings, etc. Once a sequence is created, those settings are committed.
Importing an FCP XML undoubtedly requires PPro to interpret things like framesize/framerate, but hardware settings inside FCP are likely so different that I just don’t see a proper conversion being possible, say from AJA FCP-to-AJA Adobe, without some work from the hardware company as the hooks, the interface, the options and the drivers are different.
Copy/Paste (as you noted) into a new, properly configured sequence is a relatively small leap to otherwise maintain the edited FCP timeline.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Alex Schwindt
July 12, 2011 at 7:15 pmEric – thanks so much for the information! I’m needing to buy a MacBook Pro in the next couple of weeks, but I really need Colorista II and Premiere Pro to play nice together.
Erik Naso
July 12, 2011 at 7:20 pm[alex schwindt] “I’m needing to buy a MacBook Pro in the next couple of weeks, but I really need Colorista II and Premiere Pro to play nice together”
They play better than before but Colorista II still will kick you in the shins every once in a while.
It works better in FCP but I’m sure it will catch up. Please let Red Giant know that you want it to work better that’s the only way things get fixed if demand is high.Blog https://www.eriknaso.com
David Robillard
August 28, 2014 at 9:33 pmSorry the issue with Colorista II working in Premiere Pro hasn’t got any better. I’ve noticed this has been an issue dating back to 2011 and it’s now August 2014.
Glad I purchased Colorista, the funny thing is that Red Giant Looks isn’t near this bad.
Dave
David Robillard
