Activity Forums Adobe Premiere Pro Red frames on Premiere
  • Red frames on Premiere
    Posted by Alex Ojeda on March 8, 2015 at 3:31 pm
    I am having this issue now, never heard of this problem until now. And its happening inside projects that had been ok since a few months back when I finish them. I just went in to export again some of the sequences and now the red frames are all over like a plague. Its Canon footage from an XF300. Ive deleted media cache files, digital rebellion house clean, and now that I want to restart premiere it keeps on crashing while loading the media files, I relaunch again and it loads some more files and goes a bit further until if finally stops crashing after 3 -4 times. I tried the following solution suggested by an Adobe guy: offline clips, delete media cache, save project, close project, link again, and the red frames were gone from the timeline, but they did show up in the exported movie!! I need to deliver this to client this Monday!! Is there any fix to this? I been using this project for a few months exporting movies with no problem until now, but I haven’t changed anything in the project. What caused it? What should I do to fix this asap. Please help! Im using Premiere CC 2014 latest update 8.1 Many thanks!
    Alex Ojeda
    http://www.alexojeda.com
    Alex Ojeda replied 11 years, 6 months ago 2 Members · 3 Replies
  • Alex Ojeda
    March 8, 2015 at 7:06 pm
    Im running on Premiere Pro 8.1 caravan OSX 10.9.2
    Alex Ojeda
    March 9, 2015 at 8:35 am
    Hey Alex,
    It is a known problem for the second to last version of Premiere Pro CC. I thought that they had fixed it by now, as I am no longer getting them.
    However, based on advice I received at the time one should use the “Media Browser” within Premiere Pro to import tapeless footage. Rather than doing the drag & drop straight into the project panel. Since doing this, I have seen none of the annoying red flashes.
    If your project is an older version, it may be worth considering setting up a new project and import all the timelines from the old one into that.
    All the Best
    @madsvid, London, UK
    Check out my other hangouts:
    Twitter: @madsvid
    https://mads-thinkingoutloud.blogspot.co.uk
  • Alex Ojeda
    March 17, 2015 at 9:25 am
    Hi, Mads,
    Many thanks for the info. Ive never imported footage by dragging and dropping. Ive always used the media browser. I did a bit of research and apparently that red frames bug came back strong in version 8.2, and affects most commonly mxf files, randomly attacking some users.
    I rolled back to Premiere 8.1 and AME 8.0.1 and now im good. I’ll wait a while before updating again.
    Again, many thanks!
    Best,
    Alex
    Alex Ojeda
